In the left navigation pane, click the Signal Review
icon ().
From the Manage Reference Data menu (), on the top right, click Manage Views.
Click the Row Action menu () for a signal view, and then click Rename.
In addition to the information you can change in the steps below,
the Rename Signal View page shows the following information about the
view:
The ordered list of columns included on the Product-Event
Combinations page.
The sort order for the Product-Event Combinations
table.
The SQL WHERE clause, if any, that selects the
product-event combinations to appear in the Product-Event Combinations
table.
In the View name field, enter a new view name.
In the Description field, enter an informative
description of the view.
Optionally, change the Category assignment for the
view.
To add the view to an existing category, select
Add to existing category and select the view
from the drop-down list.
To add a new category, select Add to a new
category named and type the category name in the text
box.
Optionally, change the Review period for the view by
selecting it from the Review period drop-down list. This
option is available if the signal configuration has the review period feature
set up.
