Submit a review for a product-event combination
If you added a topic during Submit Review, a folder appears in the Status column. Oracle Empirica Signal also updates the reviewed alert counts for the product in the SOC cards, Product Summary at the top of the page, and the Detail panel.
If you are working with signal configurations connected via multisource signal configuration, some information is shared between the lead configuration and the multisource signal configuration (comments, topics) and other information is independent (alerts). When you submit a review in a connected configuration, the affects on the multisource signal configuration and the lead configuration differ.When you review a product-event combination row of a connected configuration the following takes place:
- The product-event combination row in all connected configurations are updated with the comment and, if applicable, topic information.
- Only the alerts from the selected configuration are marked as
reviewed.
- If you are working in the multisource signal configuration, only alerts in the multisource signal configuration are marked as reviewed.
- If you are working in the lead configuration, only alerts in the lead configuration are marked as reviewed.
- The product-event combination row and the tables, such as Signal History, in each respective configuration will reflect the changes applied as described above.
Parent topic: Step 4: Submit the review
