- User Guide and Online Help
- Retrieve and review data mining results
- View results graphs
- Work with results graphs
- In the left navigation pane, hover on the Data Analysis
icon (
), then click Data Mining Results. - On the Select Criteria page, choose the run. Your Default Run user preference determines which run is selected by default.
- To view all available runs, click Browse.
- To see the details of the run, click View Run Details, examine the details, then click Close.
- Specify the selection criteria by completing steps 3 through 5 on Load the run and select variables.
- Click Choose Graph.
- From the Associations selected for graphing, select the
graph to generate and select options from the list below.
Option Check to Popup
Display each graph in an individual window. If you have popup blocking software installed on your PC, it may prevent these windows from opening. You may want to disable your popup blocking software.
Key
Display a color key below the graph to show which value each graph element (such as a bar or region of the graph) represents. You can modify the graph key as needed.
Notes
Display notes about the graph.
Links
Show the following:
- For some graphs, information about what a graph component (such as a bar, cell, or region) represents, or statistics for the component, that appears when you point to that component.
- A menu that allows you to drill down when you click a graph component.
- Print link.
- Save to Topic link (if Topics has been configured to offer this feature).
- For some graphs, links to download graph data.
- Click Display.
Parent topic: View results graphs
