1 Apply the 9.2.0.2 patch to Oracle Empirica Signal
- Prepare to upgrade
To upgrade, you must confirm the version number of your instance of Oracle Empirica Signal and ensure all users are logged out. - Unpack the Oracle Empirica Signal patch files
On the application server running Oracle Empirica Signal 9.2.0.x, create a directory to unpack and run the upgrade script. - Update listener.properties file
Confirm the RGPS Minimum Lambda parameters in the listener.properties file. - Deploy Oracle Empirica Signal
After you have unpacked the Oracle Empirica Signal upgrade files on the application server running Oracle Empirica Signal, you must deploy the Signal application in the Oracle WebLogic Server console. - Update Oracle Analytics Server
Complete the following steps if an Oracle Analytics Server (OAS) was set up for Empirica Topics reporting. - Restart OAS Server
After you update the application server running OAS, you must restart the BI server in the WebLogic Server console. - Confirm the upgrade
Confirm that the upgrade succeeded and notify users.
