Act Configuration Artifacts
Because some RMIMs and CMETs tolerate different conformance profiles for the same object type, and because there is no information in the RMIM that determines for OMP which conformance to use , OMP uses the information in the Act Concept configuration table to define the appropriate conformance. The tables listed in the following sections define all occurrences in OMP-supported models that either have seed data or require additional client configuration, for both RMIMs and CMETs.
