CodeSystem Delta Add Operation
post
/oracle-fhir-server/fhir/CodeSystem/$apply-codesystem-delta-add
The $apply-codesystem-delta-add operation can be used to add concepts to an existing external Codeystem.
Request
There are no request parameters for this operation.
Supported Media Types
- application/fhir+json
FHIR Parameters Resource
Root Schema : schema
Type:
objectFHIR Parameters Resource
Example:
"resourceType": "Parameters",
"parameter": [
"name": "system",
"valueUri": "http://example.com/labCodes"
"name": "file",
"valueAttachment": {
"contentType": "text/csv",
"data": "Q09ERSxESVNQTEFZCgpDSEVNLENoZW1pc3RyeQpIQixIZW1vZ2xvYmluCk5FVVQsTmV1dHJvcGhpbHMKTUlDUk8sTWljcm9iaW9sb2d5CkMmUyxDdWx0dXJlIGFuZCBTZW5zaXRpdml0eQ==",
"url": "file:/concepts.csv"
}Response
200 Response
Success
Root Schema : FHIR-SAMPLE-JSON-RESPONSE
Type:
Example:
"parameter": [ {
"name": "conceptCount",
"valueInteger": 2
"name": "target",
"valueReference": {
"reference": "CodeSystem/150002"
