Type-Level Expunge Operation
post
/oracle-fhir-server/fhir/Device/$expunge
The $expunge operation can be invoked at the type level. In this mode, all resources of a given Device reource type will be processed with the same rules as at the instance level.
Request
There are no request parameters for this operation.
Supported Media Types
- application/fhir+json
FHIR Parameters Resource
Root Schema : schema
Type:
objectFHIR Parameters Resource
Example:
"resourceType": "Parameters",
"parameter": [ {
"name": "limit",
"valueInteger": 0
"name": "expungeDeletedResources",
"valueBoolean": false
"name": "expungePreviousVersions",
"name": "expungeEverything",
"name": "count"
}Response
200 Response
Success
Root Schema : FHIR-JSON-RESOURCE
Type:
objectA FHIR resource
