Create Device Resource
post
/oracle-fhir-server/fhir/Device
This api lets you create a new instance of the Device resource.
Request
There are no request parameters for this operation.
Supported Media Types
- application/fhir+json
Root Schema : schema
Type:
Show Source
object-
_distinctIdentifier: object
Element
_expirationDate: object
Element
_implicitRules: object
Element
_language: object
Element
_lotNumber: object
Element
_manufactureDate: object
Element
_manufacturer: object
Element
_modelNumber: object
Element
_partNumber: object
Element
_serialNumber: object
Element
_status: object
Element
_url: object
Element
contact: array
contact
Contact details for an organization or a particular human that is responsible for the device.
contained: array
contained
These resources do not have an independent existence apart from the resource that contains them - they cannot be identified independently, and nor can they have their own independent transaction scope.
definition: object
Reference
deviceName: array
deviceName
This represents the manufacturer's name of the device as provided by the device, from a UDI label, or by a person describing the Device. This typically would be used when a person provides the name(s) or when the device represents one of the names available from DeviceDefinition.
distinctIdentifier: string
Pattern:
^[ \r\n\t\S]+$ -
expirationDate: string
Pattern:
^([0-9]([0-9]([0-9][1-9]|[1-9]0)|[1-9]00)|[1-9]000)(-(0[1-9]|1[0-2])(-(0[1-9]|[1-2][0-9]|3[0-1])(T([01][0-9]|2[0-3]):[0-5][0-9]:([0-5][0-9]|60)(\.[0-9]+)?(Z|(\+|-)((0[0-9]|1[0-3]):[0-5][0-9]|14:00)))?)?)?$ -
extension: array
extension
May be used to represent additional information that is not part of the basic definition of the resource. To make the use of extensions safe and manageable, there is a strict set of governance applied to the definition and use of extensions. Though any implementer can define an extension, there is a set of requirements that SHALL be met as part of the definition of the extension.
Pattern:
^[A-Za-z0-9\-\.]{1,64}$ -
identifier: array
identifier
Unique instance identifiers assigned to a device by manufacturers other organizations or owners.
implicitRules: string
Pattern:
^\S*$ -
language: string
Pattern:
^[^\s]+(\s[^\s]+)*$ -
Reference
lotNumber: string
Pattern:
^[ \r\n\t\S]+$ -
manufactureDate: string
Pattern:
manufacturer: string
Pattern:
^[ \r\n\t\S]+$ -
meta: object
Meta
modelNumber: string
Pattern:
^[ \r\n\t\S]+$ -
modifierExtension: array
modifierExtension
May be used to represent additional information that is not part of the basic definition of the resource and that modifies the understanding of the element that contains it and/or the understanding of the containing element's descendants. Usually modifier elements provide negation or qualification. To make the use of extensions safe and manageable, there is a strict set of governance applied to the definition and use of extensions. Though any implementer is allowed to define an extension, there is a set of requirements that SHALL be met as part of the definition of the extension. Applications processing a resource are required to check for modifier extensions. Modifier extensions SHALL NOT change the meaning of any elements on Resource or DomainResource (including cannot change the meaning of modifierExtension itself).
note: array
note
Descriptive information, usage information or implantation information that is not captured in an existing element.
owner: object
Reference
parent: object
Reference
partNumber: string
Pattern:
^[ \r\n\t\S]+$ -
patient: object
Reference
property: array
property
The actual configuration settings of a device as it actually operates, e.g., regulation status, time properties.
resourceType(required):
This is a Device resource
safety: array
safety
Provides additional safety characteristics about a medical device. For example devices containing latex.
serialNumber: string
Pattern:
^[ \r\n\t\S]+$ -
specialization: array
specialization
The capabilities supported on a device, the standards to which the device conforms for a particular purpose, and used for the communication.
status: string
Allowed Values:
[ "active", "inactive", "entered-in-error", "unknown" ]Status of the Device availability. -
statusReason: array
statusReason
Reason for the dtatus of the Device availability.
text: object
Narrative
type: object
CodeableConcept
udiCarrier: array
udiCarrier
Unique device identifier (UDI) assigned to device label or package. Note that the Device may include multiple udiCarriers as it either may include just the udiCarrier for the jurisdiction it is sold, or for multiple jurisdictions it could have been sold.
url: string
Pattern:
^\S*$ -
version: array
version
The actual design of the device or software version running on the device.
Nested Schema : Element
Type:
Show Source
object-
extension: array
extension
May be used to represent additional information that is not part of the basic definition of the element. To make the use of extensions safe and manageable, there is a strict set of governance applied to the definition and use of extensions. Though any implementer can define an extension, there is a set of requirements that SHALL be met as part of the definition of the extension.
Pattern:
^[ \r\n\t\S]+$
Nested Schema : contact
Type:
arrayContact details for an organization or a particular human that is responsible for the device.
Show Source
Nested Schema : contained
Type:
arrayThese resources do not have an independent existence apart from the resource that contains them - they cannot be identified independently, and nor can they have their own independent transaction scope.
Show Source
Array of:
object ResourceList
One of FHIR Resource: Ref: FHIR 4.0.1 specification.
Nested Schema : Reference
Type:
Show Source
object-
_display: object
Element
_reference: object
Element
_type: object
Element
display: string
Pattern:
^[ \r\n\t\S]+$ -
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
identifier: object
Identifier
reference: string
Pattern:
^[ \r\n\t\S]+$ -
type: string
Pattern:
^\S*$
Nested Schema : deviceName
Type:
arrayThis represents the manufacturer's name of the device as provided by the device, from a UDI label, or by a person describing the Device. This typically would be used when a person provides the name(s) or when the device represents one of the names available from DeviceDefinition.
Show Source
Nested Schema : extension
Type:
arrayMay be used to represent additional information that is not part of the basic definition of the resource. To make the use of extensions safe and manageable, there is a strict set of governance applied to the definition and use of extensions. Though any implementer can define an extension, there is a set of requirements that SHALL be met as part of the definition of the extension.
Show Source
Nested Schema : identifier
Type:
arrayUnique instance identifiers assigned to a device by manufacturers other organizations or owners.
Show Source
Nested Schema : Meta
Type:
Show Source
object-
_lastUpdated: object
Element
_source: object
Element
_versionId: object
Element
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
lastUpdated: string
Pattern:
^([0-9]([0-9]([0-9][1-9]|[1-9]0)|[1-9]00)|[1-9]000)-(0[1-9]|1[0-2])-(0[1-9]|[1-2][0-9]|3[0-1])T([01][0-9]|2[0-3]):[0-5][0-9]:([0-5][0-9]|60)(\.[0-9]+)?(Z|(\+|-)((0[0-9]|1[0-3]):[0-5][0-9]|14:00))$ -
profile: array
profile
A list of profiles (references to [[[StructureDefinition]]] resources) that this resource claims to conform to. The URL is a reference to [[[StructureDefinition.url]]].
security: array
security
Security labels applied to this resource. These tags connect specific resources to the overall security policy and infrastructure.
source: string
Pattern:
^\S*$ -
tag: array
tag
Tags applied to this resource. Tags are intended to be used to identify and relate resources to process and workflow, and applications are not required to consider the tags when interpreting the meaning of a resource.
versionId: string
Pattern:
Nested Schema : modifierExtension
Type:
arrayMay be used to represent additional information that is not part of the basic definition of the resource and that modifies the understanding of the element that contains it and/or the understanding of the containing element's descendants. Usually modifier elements provide negation or qualification. To make the use of extensions safe and manageable, there is a strict set of governance applied to the definition and use of extensions. Though any implementer is allowed to define an extension, there is a set of requirements that SHALL be met as part of the definition of the extension. Applications processing a resource are required to check for modifier extensions.
Show Source
Nested Schema : note
Type:
arrayDescriptive information, usage information or implantation information that is not captured in an existing element.
Show Source
Nested Schema : property
Type:
arrayThe actual configuration settings of a device as it actually operates, e.g., regulation status, time properties.
Show Source
Nested Schema : safety
Type:
arrayProvides additional safety characteristics about a medical device. For example devices containing latex.
Show Source
Nested Schema : specialization
Type:
arrayThe capabilities supported on a device, the standards to which the device conforms for a particular purpose, and used for the communication.
Show Source
Nested Schema : statusReason
Type:
arrayReason for the dtatus of the Device availability.
Show Source
Nested Schema : Narrative
Type:
Show Source
object-
_status: object
Element
div(required):
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
status: string
Allowed Values:
[ "generated", "extensions", "additional", "empty" ]The status of the narrative - whether it's entirely generated (from just the defined data or the extensions too), or whether a human authored it and it may contain additional data.
Nested Schema : CodeableConcept
Type:
Show Source
object-
_text: object
Element
coding: array
coding
A reference to a code defined by a terminology system.
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
text: string
Pattern:
^[ \r\n\t\S]+$
Nested Schema : udiCarrier
Type:
arrayUnique device identifier (UDI) assigned to device label or package. Note that the Device may include multiple udiCarriers as it either may include just the udiCarrier for the jurisdiction it is sold, or for multiple jurisdictions it could have been sold.
Show Source
Nested Schema : version
Type:
arrayThe actual design of the device or software version running on the device.
Show Source
Type:
arrayMay be used to represent additional information that is not part of the basic definition of the element. To make the use of extensions safe and manageable, there is a strict set of governance applied to the definition and use of extensions. Though any implementer can define an extension, there is a set of requirements that SHALL be met as part of the definition of the extension.
Show Source
Nested Schema : Extension
Type:
Show Source
object-
_url: object
Element
_valueBase64Binary: object
Element
_valueBoolean: object
Element
_valueCanonical: object
Element
_valueCode: object
Element
_valueDate: object
Element
_valueDateTime: object
Element
_valueDecimal: object
Element
_valueId: object
Element
_valueInstant: object
Element
_valueInteger: object
Element
_valueMarkdown: object
Element
_valueOid: object
Element
_valuePositiveInt: object
Element
_valueString: object
Element
_valueTime: object
Element
_valueUnsignedInt: object
Element
_valueUri: object
Element
_valueUrl: object
Element
_valueUuid: object
Element
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
url: string
Pattern:
^\S*$ -
valueAddress: object
Address
valueAge: object
Age
valueAnnotation: object
Annotation
valueAttachment: object
valueBase64Binary: string
Pattern:
^(\s*([0-9a-zA-Z\+/=]){4}\s*)+$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueBoolean: boolean
Pattern:
^true|false$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueCanonical: string
Pattern:
^\S*$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueCode: string
Pattern:
^[^\s]+(\s[^\s]+)*$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueCodeableConcept: object
CodeableConcept
valueCoding: object
Coding
valueContactDetail: object
ContactDetail
valueContactPoint: object
ContactPoint
valueContributor: object
Contributor
valueCount: object
Count
valueDataRequirement: object
DataRequirement
valueDate: string
Pattern:
^([0-9]([0-9]([0-9][1-9]|[1-9]0)|[1-9]00)|[1-9]000)(-(0[1-9]|1[0-2])(-(0[1-9]|[1-2][0-9]|3[0-1]))?)?$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueDateTime: string
Pattern:
^([0-9]([0-9]([0-9][1-9]|[1-9]0)|[1-9]00)|[1-9]000)(-(0[1-9]|1[0-2])(-(0[1-9]|[1-2][0-9]|3[0-1])(T([01][0-9]|2[0-3]):[0-5][0-9]:([0-5][0-9]|60)(\.[0-9]+)?(Z|(\+|-)((0[0-9]|1[0-3]):[0-5][0-9]|14:00)))?)?)?$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueDecimal: number
Pattern:
^-?(0|[1-9][0-9]*)(\.[0-9]+)?([eE][+-]?[0-9]+)?$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueDistance: object
Distance
valueDosage: object
Dosage
valueDuration: object
Duration
valueExpression: object
Expression
valueHumanName: object
HumanName
valueId: string
Pattern:
^[A-Za-z0-9\-\.]{1,64}$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueIdentifier: object
Identifier
valueInstant: string
Pattern:
^([0-9]([0-9]([0-9][1-9]|[1-9]0)|[1-9]00)|[1-9]000)-(0[1-9]|1[0-2])-(0[1-9]|[1-2][0-9]|3[0-1])T([01][0-9]|2[0-3]):[0-5][0-9]:([0-5][0-9]|60)(\.[0-9]+)?(Z|(\+|-)((0[0-9]|1[0-3]):[0-5][0-9]|14:00))$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueInteger: number
Pattern:
^-?([0]|([1-9][0-9]*))$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueMarkdown: string
Pattern:
^[ \r\n\t\S]+$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueMeta: object
Meta
valueMoney: object
Money
valueOid: string
Pattern:
^urn:oid:[0-2](\.(0|[1-9][0-9]*))+$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueParameterDefinition: object
ParameterDefinition
valuePeriod: object
Period
valuePositiveInt: number
Pattern:
^[1-9][0-9]*$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueQuantity: object
Quantity
valueRange: object
Range
valueRatio: object
Ratio
valueReference: object
Reference
valueRelatedArtifact: object
RelatedArtifact
valueSampledData: object
SampledData
valueSignature: object
Signature
valueString: string
Pattern:
valueTime: string
Pattern:
^([01][0-9]|2[0-3]):[0-5][0-9]:([0-5][0-9]|60)(\.[0-9]+)?$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueTiming: object
Timing
valueTriggerDefinition: object
TriggerDefinition
valueUnsignedInt: number
Pattern:
^[0]|([1-9][0-9]*)$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list). -
valueUri: string
Pattern:
valueUrl: string
Pattern:
valueUsageContext: object
UsageContext
valueUuid: string
Pattern:
^urn:uuid:[0-9a-f]{8}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{12}$Value of extension - must be one of a constrained set of the data types (see [Extensibility](extensibility.html) for a list).
Type:
Show Source
Nested Schema : Address
Type:
Show Source
object-
_city: object
Element
_country: object
Element
_district: object
Element
_line: array
_line
Extensions for line
_postalCode: object
Element
_state: object
Element
_text: object
Element
_type: object
Element
_use: object
Element
city: string
Pattern:
^[ \r\n\t\S]+$ -
country: string
Pattern:
^[ \r\n\t\S]+$ -
district: string
Pattern:
^[ \r\n\t\S]+$ -
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
line: array
line
This component contains the house number, apartment number, street name, street direction, P.O. Box number, delivery hints, and similar address information.
period: object
Period
postalCode: string
Pattern:
^[ \r\n\t\S]+$ -
state: string
Pattern:
^[ \r\n\t\S]+$ -
text: string
Pattern:
^[ \r\n\t\S]+$ -
type: string
Allowed Values:
[ "postal", "physical", "both" ]Distinguishes between physical addresses (those you can visit) and mailing addresses (e.g. PO Boxes and care-of addresses). Most addresses are both. -
use: string
Allowed Values:
[ "home", "work", "temp", "old", "billing" ]The purpose of this address.
Nested Schema : Age
Type:
Show Source
object-
_code: object
Element
_comparator: object
Element
_system: object
Element
_unit: object
Element
_value: object
Element
code: string
Pattern:
comparator: string
Allowed Values:
[ "<", "<=", ">=", ">" ]How the value should be understood and represented - whether the actual value is greater or less than the stated value due to measurement issues; e.g. if the comparator is "<" , then the real value is < stated value.< div> "> -
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
system: string
Pattern:
^\S*$ -
unit: string
Pattern:
^[ \r\n\t\S]+$ -
value: number
Pattern:
Nested Schema : Annotation
Type:
Show Source
object-
_authorString: object
Element
_text: object
Element
_time: object
Element
authorReference: object
Reference
authorString: string
Pattern:
^[ \r\n\t\S]+$The individual responsible for making the annotation. -
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
text: string
Pattern:
^[ \r\n\t\S]+$ -
time: string
Pattern:
Nested Schema : Attachment
Type:
Show Source
object-
_contentType: object
Element
_creation: object
Element
_data: object
Element
_hash: object
Element
_language: object
Element
_size: object
Element
_title: object
Element
_url: object
Element
contentType: string
Pattern:
creation: string
Pattern:
data: string
extension: array
extension
hash: string
Pattern:
^[ \r\n\t\S]+$ -
language: string
Pattern:
Pattern:
^[0]|([1-9][0-9]*)$ -
title: string
Pattern:
^[ \r\n\t\S]+$ -
url: string
Pattern:
^\S*$
Nested Schema : Coding
Type:
Show Source
object-
_code: object
Element
_display: object
Element
_system: object
Element
_userSelected: object
Element
_version: object
Element
code: string
Pattern:
display: string
Pattern:
^[ \r\n\t\S]+$ -
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
system: string
Pattern:
^\S*$ -
userSelected: boolean
Pattern:
^true|false$ -
version: string
Pattern:
^[ \r\n\t\S]+$
Nested Schema : ContactDetail
Type:
Show Source
object-
_name: object
Element
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
Pattern:
^[ \r\n\t\S]+$ -
telecom: array
telecom
The contact details for the individual (if a name was provided) or the organization.
Nested Schema : ContactPoint
Type:
Show Source
object-
_rank: object
Element
_system: object
Element
_use: object
Element
_value: object
Element
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
period: object
Period
rank: number
Pattern:
^[1-9][0-9]*$ -
system: string
Allowed Values:
[ "phone", "fax", "email", "pager", "url", "sms", "other" ]Telecommunications form for contact point - what communications system is required to make use of the contact. -
use: string
Allowed Values:
[ "home", "work", "temp", "old", "mobile" ]Identifies the purpose for the contact point. -
value: string
Pattern:
^[ \r\n\t\S]+$
Nested Schema : Contributor
Type:
Show Source
object-
_name: object
Element
_type: object
Element
contact: array
contact
Contact details to assist a user in finding and communicating with the contributor.
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
Pattern:
^[ \r\n\t\S]+$ -
type: string
Allowed Values:
[ "author", "editor", "reviewer", "endorser" ]The type of contributor.
Nested Schema : Count
Type:
Show Source
object-
_code: object
Element
_comparator: object
Element
_system: object
Element
_unit: object
Element
_value: object
Element
code: string
Pattern:
comparator: string
Allowed Values:
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
system: string
Pattern:
^\S*$ -
unit: string
Pattern:
^[ \r\n\t\S]+$ -
value: number
Pattern:
Nested Schema : DataRequirement
Type:
Show Source
object-
_limit: object
Element
_mustSupport: array
_mustSupport
Extensions for mustSupport
_type: object
Element
codeFilter: array
codeFilter
Code filters specify additional constraints on the data, specifying the value set of interest for a particular element of the data. Each code filter defines an additional constraint on the data, i.e. code filters are AND'ed, not OR'ed.
dateFilter: array
dateFilter
Date filters specify additional constraints on the data in terms of the applicable date range for specific elements. Each date filter specifies an additional constraint on the data, i.e. date filters are AND'ed, not OR'ed.
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
limit: number
Pattern:
^[1-9][0-9]*$ -
mustSupport: array
mustSupport
Indicates that specific elements of the type are referenced by the knowledge module and must be supported by the consumer in order to obtain an effective evaluation. This does not mean that a value is required for this element, only that the consuming system must understand the element and be able to provide values for it if they are available. The value of mustSupport SHALL be a FHIRPath resolveable on the type of the DataRequirement. The path SHALL consist only of identifiers, constant indexers, and .resolve() (see the [Simple FHIRPath Profile](fhirpath.html#simple) for full details).
profile: array
profile
The profile of the required data, specified as the uri of the profile definition.
sort: array
sort
Specifies the order of the results to be returned.
subjectCodeableConcept: object
CodeableConcept
subjectReference: object
Reference
type: string
Pattern:
^[^\s]+(\s[^\s]+)*$
Nested Schema : Distance
Type:
Show Source
object-
_code: object
Element
_comparator: object
Element
_system: object
Element
_unit: object
Element
_value: object
Element
code: string
Pattern:
comparator: string
Allowed Values:
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
system: string
Pattern:
^\S*$ -
unit: string
Pattern:
^[ \r\n\t\S]+$ -
value: number
Pattern:
Nested Schema : Dosage
Type:
Show Source
object-
_asNeededBoolean: object
Element
_patientInstruction: object
Element
_sequence: object
Element
_text: object
Element
additionalInstruction: array
Supplemental instructions to the patient on how to take the medication (e.g. "with meals" or"take half to one hour before food") or warnings for the patient about the medication (e.g. "may cause drowsiness" or "avoid exposure of skin to direct sunlight or sunlamps").
asNeededBoolean: boolean
Pattern:
^true|false$Indicates whether the Medication is only taken when needed within a specific dosing schedule (Boolean option), or it indicates the precondition for taking the Medication (CodeableConcept). -
asNeededCodeableConcept: object
CodeableConcept
doseAndRate: array
doseAndRate
The amount of medication administered.
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
maxDosePerAdministration: object
Quantity
maxDosePerLifetime: object
Quantity
maxDosePerPeriod: object
Ratio
method: object
CodeableConcept
modifierExtension
May be used to represent additional information that is not part of the basic definition of the element and that modifies the understanding of the element in which it is contained and/or the understanding of the containing element's descendants. Usually modifier elements provide negation or qualification. To make the use of extensions safe and manageable, there is a strict set of governance applied to the definition and use of extensions. Though any implementer can define an extension, there is a set of requirements that SHALL be met as part of the definition of the extension. Applications processing a resource are required to check for modifier extensions. Modifier extensions SHALL NOT change the meaning of any elements on Resource or DomainResource (including cannot change the meaning of modifierExtension itself).
patientInstruction: string
Pattern:
^[ \r\n\t\S]+$ -
route: object
CodeableConcept
sequence: number
Pattern:
^-?([0]|([1-9][0-9]*))$ -
site: object
CodeableConcept
text: string
Pattern:
^[ \r\n\t\S]+$ -
timing: object
Timing
Nested Schema : Duration
Type:
Show Source
object-
_code: object
Element
_comparator: object
Element
_system: object
Element
_unit: object
Element
_value: object
Element
code: string
Pattern:
comparator: string
Allowed Values:
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
system: string
Pattern:
^\S*$ -
unit: string
Pattern:
^[ \r\n\t\S]+$ -
value: number
Pattern:
Nested Schema : Expression
Type:
Show Source
object-
_description: object
Element
_expression: object
Element
_language: object
Element
_name: object
Element
_reference: object
Element
description: string
Pattern:
^[ \r\n\t\S]+$ -
expression: string
Pattern:
^[ \r\n\t\S]+$ -
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
language: string
Allowed Values:
[ "text/cql", "text/fhirpath", "application/x-fhir-query" ]The media type of the language for the expression. -
Pattern:
reference: string
Pattern:
^\S*$
Nested Schema : HumanName
Type:
Show Source
object-
_family: object
Element
_given: array
_given
Extensions for given
_prefix: array
_prefix
Extensions for prefix
_suffix: array
_suffix
Extensions for suffix
_text: object
Element
_use: object
Element
extension: array
extension
family: string
Pattern:
^[ \r\n\t\S]+$ -
given: array
given
Given name.
Pattern:
^[ \r\n\t\S]+$ -
period: object
Period
prefix: array
prefix
Part of the name that is acquired as a title due to academic, legal, employment or nobility status, etc. and that appears at the start of the name.
suffix: array
suffix
Part of the name that is acquired as a title due to academic, legal, employment or nobility status, etc. and that appears at the end of the name.
text: string
Pattern:
^[ \r\n\t\S]+$ -
use: string
Allowed Values:
[ "usual", "official", "temp", "nickname", "anonymous", "old", "maiden" ]Identifies the purpose for this name.
Nested Schema : Identifier
Type:
Show Source
object-
_system: object
Element
_use: object
Element
_value: object
Element
assigner: object
Reference
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
period: object
Period
system: string
Pattern:
^\S*$ -
type: object
CodeableConcept
use: string
Allowed Values:
[ "usual", "official", "temp", "secondary", "old" ]The purpose of this identifier. -
value: string
Pattern:
^[ \r\n\t\S]+$
Nested Schema : Money
Type:
Show Source
object-
_currency: object
Element
_value: object
Element
currency: string
Pattern:
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
value: number
Pattern:
Nested Schema : ParameterDefinition
Type:
Show Source
object-
_documentation: object
Element
_max: object
Element
_min: object
Element
_name: object
Element
_type: object
Element
_use: object
Element
documentation: string
Pattern:
^[ \r\n\t\S]+$ -
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
max: string
Pattern:
^[ \r\n\t\S]+$ -
min: number
Pattern:
Pattern:
profile: string
Pattern:
^\S*$ -
type: string
Pattern:
use: string
Pattern:
^[^\s]+(\s[^\s]+)*$
Nested Schema : Period
Type:
Show Source
object-
_end: object
Element
_start: object
Element
end: string
Pattern:
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
start: string
Pattern:
Nested Schema : Quantity
Type:
Show Source
object-
_code: object
Element
_comparator: object
Element
_system: object
Element
_unit: object
Element
_value: object
Element
code: string
Pattern:
comparator: string
Allowed Values:
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
system: string
Pattern:
^\S*$ -
unit: string
Pattern:
^[ \r\n\t\S]+$ -
value: number
Pattern:
Nested Schema : Range
Type:
Show Source
object-
extension: array
extension
high: object
Quantity
Pattern:
^[ \r\n\t\S]+$ -
low: object
Quantity
Nested Schema : Ratio
Type:
Show Source
object-
denominator: object
Quantity
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
numerator: object
Quantity
Nested Schema : RelatedArtifact
Type:
Show Source
object-
_citation: object
Element
_display: object
Element
_label: object
Element
_type: object
Element
_url: object
Element
citation: string
Pattern:
^[ \r\n\t\S]+$ -
display: string
Pattern:
^[ \r\n\t\S]+$ -
document: object
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
label: string
Pattern:
^[ \r\n\t\S]+$ -
resource: string
Pattern:
^\S*$ -
type: string
Allowed Values:
[ "documentation", "justification", "citation", "predecessor", "successor", "derived-from", "depends-on", "composed-of" ]The type of relationship to the related artifact. -
url: string
Pattern:
^\S*$
Nested Schema : SampledData
Type:
Show Source
object-
_data: object
Element
_dimensions: object
Element
_factor: object
Element
_lowerLimit: object
Element
_period: object
Element
_upperLimit: object
Element
data: string
Pattern:
^[ \r\n\t\S]+$ -
dimensions: number
Pattern:
^[1-9][0-9]*$ -
extension: array
extension
factor: number
Pattern:
^-?(0|[1-9][0-9]*)(\.[0-9]+)?([eE][+-]?[0-9]+)?$ -
Pattern:
^[ \r\n\t\S]+$ -
lowerLimit: number
Pattern:
origin(required): object
Quantity
period: number
Pattern:
upperLimit: number
Pattern:
Nested Schema : Signature
Type:
Show Source
object-
_data: object
Element
_sigFormat: object
Element
_targetFormat: object
Element
_when: object
Element
data: string
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
onBehalfOf: object
Reference
sigFormat: string
Pattern:
targetFormat: string
Pattern:
type(required): array
type
An indication of the reason that the entity signed this document. This may be explicitly included as part of the signature information and can be used when determining accountability for various actions concerning the document.
when: string
Pattern:
who(required): object
Reference
Nested Schema : Timing
Type:
Show Source
object-
_event: array
_event
Extensions for event
code: object
CodeableConcept
event: array
event
Identifies specific times when the event occurs.
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
modifierExtension
repeat: object
Timing_Repeat
Nested Schema : TriggerDefinition
Type:
Show Source
object-
_name: object
Element
_timingDate: object
Element
_timingDateTime: object
Element
_type: object
Element
condition: object
Expression
data: array
data
The triggering data of the event (if this is a data trigger). If more than one data is requirement is specified, then all the data requirements must be true.
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
Pattern:
^[ \r\n\t\S]+$ -
timingDate: string
Pattern:
^([0-9]([0-9]([0-9][1-9]|[1-9]0)|[1-9]00)|[1-9]000)(-(0[1-9]|1[0-2])(-(0[1-9]|[1-2][0-9]|3[0-1]))?)?$The timing of the event (if this is a periodic trigger). -
timingDateTime: string
Pattern:
^([0-9]([0-9]([0-9][1-9]|[1-9]0)|[1-9]00)|[1-9]000)(-(0[1-9]|1[0-2])(-(0[1-9]|[1-2][0-9]|3[0-1])(T([01][0-9]|2[0-3]):[0-5][0-9]:([0-5][0-9]|60)(\.[0-9]+)?(Z|(\+|-)((0[0-9]|1[0-3]):[0-5][0-9]|14:00)))?)?)?$The timing of the event (if this is a periodic trigger). -
timingReference: object
Reference
timingTiming: object
Timing
type: string
Allowed Values:
[ "named-event", "periodic", "data-changed", "data-added", "data-modified", "data-removed", "data-accessed", "data-access-ended" ]The type of triggering event.
Nested Schema : UsageContext
Type:
Show Source
object-
code(required): object
Coding
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
CodeableConcept
Quantity
valueRange: object
Range
Reference
Type:
Show Source
Nested Schema : line
Type:
arrayThis component contains the house number, apartment number, street name, street direction, P.O. Box number, delivery hints, and similar address information.
Show Source
Array of:
string
Pattern:
^[ \r\n\t\S]+$
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
Show Source
Nested Schema : telecom
Type:
arrayThe contact details for the individual (if a name was provided) or the organization.
Show Source
Type:
Show Source
Type:
arrayContact details to assist a user in finding and communicating with the contributor.
Show Source
Type:
Show Source
Type:
Show Source
Nested Schema : codeFilter
Type:
arrayCode filters specify additional constraints on the data, specifying the value set of interest for a particular element of the data. Each code filter defines an additional constraint on the data, i.e. code filters are AND'ed, not OR'ed.
Show Source
Nested Schema : dateFilter
Type:
arrayDate filters specify additional constraints on the data in terms of the applicable date range for specific elements. Each date filter specifies an additional constraint on the data, i.e. date filters are AND'ed, not OR'ed.
Show Source
Type:
Show Source
Nested Schema : mustSupport
Type:
arrayIndicates that specific elements of the type are referenced by the knowledge module and must be supported by the consumer in order to obtain an effective evaluation. This does not mean that a value is required for this element, only that the consuming system must understand the element and be able to provide values for it if they are available.
Show Source
Array of:
string
Pattern:
^[ \r\n\t\S]+$
Nested Schema : profile
Type:
arrayThe profile of the required data, specified as the uri of the profile definition.
Show Source
Array of:
string
Pattern:
^\S*$
Nested Schema : DataRequirement_CodeFilter
Type:
Show Source
object-
_path: object
Element
_searchParam: object
Element
code: array
code
The codes for the code filter. If values are given, the filter will return only those data items for which the code-valued attribute specified by the path has a value that is one of the specified codes. If codes are specified in addition to a value set, the filter returns items matching a code in the value set or one of the specified codes.
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
modifierExtension
path: string
Pattern:
^[ \r\n\t\S]+$ -
searchParam: string
Pattern:
^[ \r\n\t\S]+$ -
valueSet: string
Pattern:
^\S*$
Type:
arrayThe codes for the code filter. If values are given, the filter will return only those data items for which the code-valued attribute specified by the path has a value that is one of the specified codes. If codes are specified in addition to a value set, the filter returns items matching a code in the value set or one of the specified codes.
Show Source
Type:
Show Source
Type:
arrayMay be used to represent additional information that is not part of the basic definition of the element and that modifies the understanding of the element in which it is contained and/or the understanding of the containing element's descendants. Usually modifier elements provide negation or qualification. To make the use of extensions safe and manageable, there is a strict set of governance applied to the definition and use of extensions. Though any implementer can define an extension, there is a set of requirements that SHALL be met as part of the definition of the extension. Applications processing a resource are required to check for modifier extensions.
Show Source
Nested Schema : DataRequirement_DateFilter
Type:
Show Source
object-
_path: object
Element
Element
Element
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
modifierExtension
path: string
Pattern:
^[ \r\n\t\S]+$ -
searchParam: string
Pattern:
^[ \r\n\t\S]+$ -
Pattern:
^([0-9]([0-9]([0-9][1-9]|[1-9]0)|[1-9]00)|[1-9]000)(-(0[1-9]|1[0-2])(-(0[1-9]|[1-2][0-9]|3[0-1])(T([01][0-9]|2[0-3]):[0-5][0-9]:([0-5][0-9]|60)(\.[0-9]+)?(Z|(\+|-)((0[0-9]|1[0-3]):[0-5][0-9]|14:00)))?)?)?$The value of the filter. If period is specified, the filter will return only those data items that fall within the bounds determined by the Period, inclusive of the period boundaries. If dateTime is specified, the filter will return only those data items that are equal to the specified dateTime. If a Duration is specified, the filter will return only those data items that fall within Duration before now. -
Duration
valuePeriod: object
Period
Type:
Show Source
Type:
Show Source
Nested Schema : DataRequirement_Sort
Type:
Show Source
object-
_direction: object
Element
_path: object
Element
direction: string
Allowed Values:
[ "ascending", "descending" ]The direction of the sort, ascending or descending. -
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
modifierExtension
path: string
Pattern:
^[ \r\n\t\S]+$
Type:
Show Source
Type:
Show Source
Type:
Show Source
Nested Schema : additionalInstruction
Type:
arraySupplemental instructions to the patient on how to take the medication (e.g. "with meals" or"take half to one hour before food") or warnings for the patient about the medication (e.g. "may cause drowsiness" or "avoid exposure of skin to direct sunlight or sunlamps").
Show Source
Type:
Show Source
Type:
Show Source
Nested Schema : Dosage_DoseAndRate
Type:
Show Source
object-
doseQuantity: object
Quantity
doseRange: object
Range
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
modifierExtension
rateQuantity: object
Quantity
rateRange: object
Range
rateRatio: object
Ratio
type: object
CodeableConcept
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
Show Source
Nested Schema : prefix
Type:
arrayPart of the name that is acquired as a title due to academic, legal, employment or nobility status, etc. and that appears at the start of the name.
Show Source
Array of:
string
Pattern:
^[ \r\n\t\S]+$
Nested Schema : suffix
Type:
arrayPart of the name that is acquired as a title due to academic, legal, employment or nobility status, etc. and that appears at the end of the name.
Show Source
Array of:
string
Pattern:
^[ \r\n\t\S]+$
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
Show Source
Nested Schema : type
Type:
arrayAn indication of the reason that the entity signed this document. This may be explicitly included as part of the signature information and can be used when determining accountability for various actions concerning the document.
Show Source
Nested Schema : event
Type:
arrayIdentifies specific times when the event occurs.
Show Source
Array of:
string
Pattern:
Type:
Show Source
Type:
Show Source
Nested Schema : Timing_Repeat
Type:
Show Source
object-
_count: object
Element
_countMax: object
Element
_dayOfWeek: array
_dayOfWeek
Extensions for dayOfWeek
_duration: object
Element
_durationMax: object
Element
_durationUnit: object
Element
_frequency: object
Element
_frequencyMax: object
Element
_offset: object
Element
_period: object
Element
_periodMax: object
Element
_periodUnit: object
Element
_timeOfDay: array
_timeOfDay
Extensions for timeOfDay
_when: array
_when
Extensions for when
boundsDuration: object
Duration
boundsPeriod: object
Period
boundsRange: object
Range
count: number
Pattern:
^[1-9][0-9]*$ -
countMax: number
Pattern:
^[1-9][0-9]*$ -
dayOfWeek: array
dayOfWeek
If one or more days of week is provided, then the action happens only on the specified day(s).
duration: number
Pattern:
durationMax: number
Pattern:
durationUnit: string
Allowed Values:
[ "s", "min", "h", "d", "wk", "mo", "a" ]The units of time for the duration, in UCUM units. -
extension: array
extension
frequency: number
Pattern:
^[1-9][0-9]*$ -
frequencyMax: number
Pattern:
^[1-9][0-9]*$ -
Pattern:
^[ \r\n\t\S]+$ -
modifierExtension
offset: number
Pattern:
period: number
Pattern:
periodMax: number
Pattern:
periodUnit: string
Allowed Values:
[ "s", "min", "h", "d", "wk", "mo", "a" ]The units of time for the period in UCUM units. -
timeOfDay: array
timeOfDay
Specified time of day for action to take place.
when: array
when
An approximate time period during the day, potentially linked to an event of daily living that indicates when the action should occur.
Nested Schema : dayOfWeek
Type:
arrayIf one or more days of week is provided, then the action happens only on the specified day(s).
Show Source
Array of:
string
Pattern:
^[^\s]+(\s[^\s]+)*$
Type:
Show Source
Type:
Show Source
Nested Schema : timeOfDay
Type:
arraySpecified time of day for action to take place.
Show Source
Array of:
string
Pattern:
Nested Schema : when
Type:
arrayAn approximate time period during the day, potentially linked to an event of daily living that indicates when the action should occur.
Show Source
Array of:
string
Allowed Values:
[ "MORN", "MORN.early", "MORN.late", "NOON", "AFT", "AFT.early", "AFT.late", "EVE", "EVE.early", "EVE.late", "NIGHT", "PHS", "HS", "WAKE", "C", "CM", "CD", "CV", "AC", "ACM", "ACD", "ACV", "PC", "PCM", "PCD", "PCV" ]
Nested Schema : data
Type:
arrayThe triggering data of the event (if this is a data trigger). If more than one data is requirement is specified, then all the data requirements must be true.
Show Source
Type:
Show Source
Type:
Show Source
Nested Schema : ResourceList
Type:
objectOne of FHIR Resource: Ref: FHIR 4.0.1 specification.
Type:
Show Source
Nested Schema : Device_DeviceName
Type:
Show Source
object-
_name: object
Element
_type: object
Element
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
modifierExtension
Pattern:
^[ \r\n\t\S]+$ -
type: string
Allowed Values:
[ "udi-label-name", "user-friendly-name", "patient-reported-name", "manufacturer-name", "model-name", "other" ]The type of deviceName. UDILabelName | UserFriendlyName | PatientReportedName | ManufactureDeviceName | ModelName.
Type:
Show Source
Type:
Show Source
Type:
Show Source
Type:
arrayA list of profiles (references to [[[StructureDefinition]]] resources) that this resource claims to conform to. The URL is a reference to [[[StructureDefinition.url]]].
Show Source
Array of:
string
Pattern:
^\S*$
Nested Schema : security
Type:
arraySecurity labels applied to this resource. These tags connect specific resources to the overall security policy and infrastructure.
Show Source
Nested Schema : tag
Type:
arrayTags applied to this resource. Tags are intended to be used to identify and relate resources to process and workflow, and applications are not required to consider the tags when interpreting the meaning of a resource.
Show Source
Nested Schema : Device_Property
Type:
Show Source
object-
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
modifierExtension
type(required): object
CodeableConcept
valueCode: array
valueCode
Property value as a code, e.g., NTP4 (synced to NTP).
valueQuantity: array
valueQuantity
Property value as a quantity.
Type:
Show Source
Type:
Show Source
Nested Schema : valueCode
Type:
arrayProperty value as a code, e.g., NTP4 (synced to NTP).
Show Source
Nested Schema : Device_Specialization
Type:
Show Source
object-
_version: object
Element
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
modifierExtension
systemType(required): object
CodeableConcept
version: string
Pattern:
^[ \r\n\t\S]+$
Type:
Show Source
Type:
Show Source
Type:
Show Source
Nested Schema : coding
Type:
arrayA reference to a code defined by a terminology system.
Show Source
Type:
Show Source
Nested Schema : Device_UdiCarrier
Type:
Show Source
object-
_carrierAIDC: object
Element
_carrierHRF: object
Element
_deviceIdentifier: object
Element
_entryType: object
Element
_issuer: object
Element
_jurisdiction: object
Element
carrierAIDC: string
carrierHRF: string
Pattern:
^[ \r\n\t\S]+$ -
deviceIdentifier: string
Pattern:
^[ \r\n\t\S]+$ -
entryType: string
Allowed Values:
[ "barcode", "rfid", "manual", "card", "self-reported", "unknown" ]A coded entry to indicate how the data was entered. -
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
issuer: string
Pattern:
^\S*$ -
jurisdiction: string
Pattern:
^\S*$ -
modifierExtension
Type:
Show Source
Type:
Show Source
Nested Schema : Device_Version
Type:
Show Source
object-
_value: object
Element
component: object
Identifier
extension: array
extension
Pattern:
^[ \r\n\t\S]+$ -
modifierExtension
type: object
CodeableConcept
value: string
Pattern:
^[ \r\n\t\S]+$
Type:
Show Source
Type:
Show Source
Response
201 Response
Created
