Delete Meta at Instance-Level
post
/oracle-fhir-server/fhir/Location/{id}/$meta-delete
Delete tags, profiles, and/or security labels from a Location resource.
Request
Path Parameters
id(required): string
The resource IDExample:
123
Supported Media Types
- application/fhir+json
FHIR Parameters Resource
Root Schema : schema
Type:
objectFHIR Parameters Resource
Example:
"resourceType": "Parameters",
"parameter": [ {
"name": "meta"
"name": "return"
}Response
200 Response
Success
Root Schema : FHIR-JSON-RESOURCE
Type:
objectA FHIR resource
