Conditional Create
The FHIR Conditional Create mechanism allows the client to specify a FHIR search URL alongside a resource to create. When processing the create, the server will first check if any resource already exists matching the given search. If no resources match, the create proceeds. If a resource does match, no resource is created.
In a standard REST mechanism, conditional creates place the search URL in the In-None-Exist request header. In a FHIR bundle transaction, this URL goes in Bundle.entry.request.ifNoneExist. Like a normal create, we use the HTTP method/verb of POST.
For example:
   "resourceType": "Bundle",
   "type": "transaction",
   "entry": [ {
    "fullUrl": "urn:uuid:95dbbf93-5829-46ba-9021-2545a1da3aa5",   > Placeholder ID for Patient
 "resource": {
         "resourceType": "Patient",
         "identifier": [ {
            "system": "http://acme.org/mrns",
            "value": "013872"
         "name": [ {
            "family": "Simpson",
            "given": [ "Homer" ]
      "request": {
         "method": "POST",
         "url": "Patient",
       "ifNoneExist": "Patient?identifier=http://acme.org/mrns|013872"   > Search URL for Conditional Create
      "fullUrl": "urn:uuid:124ff3c8-f251-4bd9-8c44-cc6568180eae",
      "resource": {
         "resourceType": "Observation",
         "identifier": [ {
            "system": "http://acme.org/obs",
            "value": "46252"
         "status": "final",
         "code": {
            "coding": [ {
               "system": "http://loinc",
               "code": "29463-7",
               "display": "Body Weight"
         "subject": {
          "reference": "urn:uuid:95dbbf93-5829-46ba-9021-2545a1da3aa5"  > Reference to Patient Placeholder ID
         "effectiveDateTime": "2022-02-23",
         "valueQuantity": {
            "value": 67.1,
            "unit": "kg",
            "system": "http://unitsofmeasure.org",
            "code": "kg"
      "request": {
         "method": "POST",
         "url": "Observation",
         "ifNoneExist": "Observation?identifier=http://acme.org/obs|46252"  > Search URL for Conditional Create
