Applying Deltas to CodeSystems
A pair of FHIR operations can be used to add or remove codes from the CodeSystems. These operations directly add or remove the codes from the specified CodeSystem.
Delta Add Operation: $apply-codesystem-delta-add
The $apply-codesystem-delta-add operation can be used to add concepts to an existing Codeystem.
The following example shows an invocation of the Delta Add operation. This payload should be a POST to the following URL:
http://<HOST_NAME>:<PORT>/oracle-fhir-server/fhir/CodeSystem/$apply-codesystem-delta-add
The payload is shown below:
"resourceType": "Parameters",
"parameter": [
"name": "system",
"valueUri": "http://example.com/csv"
"name": "file",
"valueAttachment": {
"contentType": "text/csv",
"data": "Q09ERSxESVNQTEFZCgpDSEVNVFJZLENoZW1pc3RyeQpIQjEsSGVtb2dsb2Jpbg==",
"url": "file:/concepts.csv"
Delta Remove Operation: $apply-codesystem-delta-remove
The $apply-codesystem-delta-remove operation can be used to remove concepts from an existing CodeSystem.
The following example shows an invocation of the Delta Remove operation. This payload should be a POST to the following URL:
http://<HOST_NAME>:<PORT>/oracle-fhir-server/fhir/CodeSystem/$apply-codesystem-delta-remove
"parameter": [
"name": "system",
"name": "file",
Parent topic: Terminology
