Cascading deletes
By enabling the cascading delete, a user can perform the delete on parent resource, then all the corresponding child resources will be deleted as well.
In order to perform a cascading delete:
- First, the
allow_cascading_deletesproperty must be enabled on the HDR-FHIR Server. - And then, to perform a cascaded delete, the client HTTP request must include either a special URL parameter (_cascade) or a special header to indicate that a cascading delete is desired.
The following example shows how to delete using a URL parameter.
Table 11-10 Delete using URL parameter
| HTTP Method | DELETE |
| URL | http(s)://<HOSTNAME>:<PORT>/oracle-fhir-server/fhir/Patient/100004?_cascade=delete |
The following example shows how to delete using HTTP header.
Table 11-11 Delete using HTTP Header
| Http Header | X-cascade.delete |
Parent topic: Deleting data
