Diff operation
Use the $diff operation to generate a differential between two versions of a resource, or between two different resources of the same type.
Differentials generated by this operation are in FHIR Patch format.
In generated differentials, where a value has changed (that is, a replace operation), an additional part value is present on the given operation called previousValue. This part shows the value as it was in the from version of the resource.
