Expanding Hierarchical CodeSystems and ValueSets
Many CodeSystem resources define concepts in a hierarchy, ex: parent code and child codes.
The hierarchy in a CodeSystem often indicates an "is-a" relationship between the parent code and the child codes. This is not always the case; the hierarchy can imply different kinds of relationships depending on the specific system.
ValueSets can be used to retrieve all of the codes that are a child of a specific code in a CodeSystem.
For example, suppose you have the following CodeSystem and there are 3 codes at the root level (P , Q and R) and each of these codes have children, some of which have further children.
"resourceType": "CodeSystem",
"url": "http://example.com/my_custom_codeSystem",
"content": "complete",
"concept": [ {
"code": "P",
"display": "Code P",
"concept": [ {
"code": "PP",
"display": "Code PP",
"concept": [ {
"code": "PPP",
"display": "Code PPP"
"code": "PQ",
"display": "Code PQ"
"code": "Q",
"display": "Code Q",
"concept": [ {
"code": "QP",
"display": "Code QP"
"code": "QQ",
"display": "Code QQ"
"code": "R",
"display": "Code R",
"concept": [ {
"code": "RP",
"display": "Code RP"
"code": "RQ",
"display": "Code RQ"
"code": "RR",
"display": "Code RR"
The hierarchy for the codes above can be visualized as follows:
|-- P
| |-- PP
| | \-- PPP
| \-- PQ
\-- Q
| |-- QP
| \-- QQ
\-- R
|-- RP
\-- RQ
\-- RR
To create a ValueSet containing all of the children of a specific code in this CodeSystem, a ValueSet with a filter can be defined:
"resourceType": "ValueSet",
"url": "http://example.com/my_custom_value_set",
"status": "active",
"compose": {
"include": [ {
"system": "http://example.com/my_custom_codeSystem",
"filter": [ {
"property": "concept",
"op": "is-a",
"value": "P"
Note that the "is-a" filter will exclude the concept itself.The following example combines an "is-a" filter with a simple explicit code inclusion in order to include the code "P" as well as all of its descendants.
"status": "active",
"compose": {
"include": [ {
"filter": [ {
"op": "is-a",
"value": "P"
"concept": [ {
"code": "P"
Parent topic: ValueSet
