Read
If you know the ID of a resource on an FHIR server, you can read back the most recent version of that resource by performing a Read operation. The Read uses an HTTP GET against the URL [baseUrl]/[resourceType]/[id].
The following example shows a simple read of the resource created and updated in the examples in Create, Update, Delete, and Patch.
Request: FHIR CRUD Read operation
Response: FHIR CRUD Read operation
The FHIR endpoint responds with a response similar to the following:
Parent topic: FHIR CRUD (Create/Read/Update/Delete) operations
