Requesting a ValueSet Hierarchical Expansion
If you would like to request parent-child relationships to be reflected in the response, you can add the includeHierarchy parameter in your request.
Example:
http://<HOST_NAME>:<PORT>/oracle-fhir-server/fhir/ValueSet/$expand?url=my_custom_value_set &includeHierarchy=true
This will return the following response:
"resourceType": "ValueSet",
"id": "200007",
"meta": {
"extension": [ {
"url": "http://hapifhir.io/fhir/StructureDefinition/valueset-expansion-message",
"valueString": "ValueSet was expanded using an expansion that was pre-calculated at 2023-08-16T20:14:35.055+05:30 (00:29:44 ago)"
"versionId": "1"
"url": "http://example.com/my_custom_value_set",
"status": "active",
"compose": {
"include": [ {
"system": "http://example.com/my_custom_codeSystem",
"filter": [ {
"property": "concept",
"op": "is-a",
"value": "P"
"concept": [ {
"code": "P"
"expansion": {
"identifier": "415a2a3c-02d5-463d-a810-e9d907146234",
"timestamp": "2023-08-16T20:44:18+05:30",
"total": 4,
"offset": 0,
"parameter": [ {
"name": "offset",
"valueInteger": 0
"name": "count",
"valueInteger": 1000
"contains": [ {
"code": "P",
"display": "Code P",
"contains": [ {
"code": "PP",
"display": "Code PP",
"contains": [ {
"code": "PPP",
"display": "Code PPP"
"code": "PQ",
"display": "Code PQ"
Parent topic: ValueSet
