General Guidelines for Installation
  • Linux X-windows should be used for the Linux Oracle Universal Installer (OUI) installation (Linux Graphical User Interface).
  • Before running the installer, be sure to backup all existing Oracle Healthcare Foundation schemas and any customizations.
  • Before running the installer, make sure that the ORACLE_HOME and PATH environment variables are setup in your session.
    For example,
    export ORACLE_HOME=/u01/app/oracle/product/122010
    export PATH=$PATH:$ORACLE_HOME/bin
  • When re-executing the installer due to a failure, enter the same details in the question prompting phase at all times. Do not delete any objects in the installation folder.
  • When re-executing the installer, if you receive OUI-10030 error messages, ignore the messages to continue using the existing Oracle Healthcare Foundation installation HOME path.
  • Convert the installer execution shell to an SH shell as the installer script executes in the SH shell of the Linux OS.
  • Text enclosed within <> in the following chapters indicate parameters and you must provide an appropriate value.
