Troubleshooting the Secondary Node Installation
Issue Fix
The installer fails to connect to the AdminServer
Verify if the AdminServer is running on the primary node by accessing the Oracle WebLogic Server Admin console from the secondary node.
The installer fails due to a wrong FMW path.
Make sure Oracle WebLogic Server is installed in the same file system location as on the primary node.
