Enable SSL (for middle tier)
It is optional to enable SSL, but Oracle recommends SSL for a production environment.
To enable SSL:
  1. Log into WebLogic Server Administration Console.
  2. Click the Environment node in the Domain Structure pane and click Servers in Environment table.
  3. Click the server where you deployed OHMPI_App.ear.
  4. Click the Configuration tab.
  5. Click the General tab.
  6. If Save is disabled, click Lock & Edit in the Change Center pane.
  7. Select the SSL Listen Port Enabled check box and enter a port number.
  8. To disable non-SSL port, deselect the Listen Port Enabled check box.
  9. Click Save.
  10. Click Activate Changes in the Change Center pane, if it is enabled.
  11. Click the Control tab.
  12. Click the Start/Stop tab.
  13. Click Restart SSL.
  14. Click Yes. You see the "SSL channels have been successfully restarted" message.
You must also configure SSL, identity, and trust. For more information, refer to Oracle® Fusion Middleware Securing Oracle WebLogic Server 12c Release 3 (12.1.3).
