Oracle database options
The Oracle Database has options that provide additional security features. OHMPI may include data that falls under HIPAA guidelines in the United States and similar guidelines elsewhere. These features can help you comply with those guidelines.
Table 3-1 Database Options
| Option | Description |
| Database Vault | OHMPI includes data that may fall under HIPAA or other regulations
outside the United States. These data are highly sensitive and only
those with a need to know should have access to it. To prevent DBAs and
others from seeing the data, Oracle recommends that Oracle Database
Vault must be used to limit access to the OHMPI schema for the OHMPI
user to prevent DBAs and other "superuser" accounts from accessing the
data.
Note: Database Vault requires a separate license. |
| Oracle Audit Vault | Oracle Audit Vault automates the audit collection, monitoring, and
reporting process, turning audit data into a key security resource for
detecting unauthorized activity. Consider using this feature to satisfy
compliance regulations such as SOX, PCI, and HIPAA, and to mitigate
security risks.
Note: Oracle Audit Vault requires a separate license. |
| Transparent Data Encryption | Transparent Data Encryption is one of the three
components of the Oracle Advanced Security option for Oracle Database
12cR1 (12.1.0.2.0) Enterprise Editions, Oracle Database 12cR2 (12.2.0.1)
Enterprise Editions and Oracle Database 19c (19.1.0) Enterprise
Editions. It provides transparent encryption of stored data to support
your compliance efforts. If you employ Transparent Data Encryption,
applications do not have to be modified and continue to work seamlessly
as before. Data is automatically encrypted when it is written to disk
and automatically decrypted when accessed by the application. Key
management is built in, eliminating the complex task of creating,
managing and securing encryption keys.
Note: The Advanced Security Option is licensed separately from the database. |
| Tablespace Encryption | Tablespace Encryption is another component of the Oracle Advanced Security option for Oracle Database 12cR1 (12.1.0.2.0) Enterprise Editions, Oracle Database 12cR2 (12.2.0.1) Enterprise Editions and Oracle Database 19c (19.1.0) Enterprise Editions. Tablespace encryption facilitates encryption of the entire tablespace contents, rather than having to configure encryption on a column-by-column basis. It encrypts data at the data file level to keep users from viewing the oracle data files directly. Oracle recommends that you perform tablespace encryption for maximum protection. |
