Search by article ID
The fastest way to search for information, including alerts, White Papers, installation verification (smoke) tests, and bulletins is by the article ID number, if you know it.
To search by article ID:
- Sign in to My Oracle Support at: https://support.oracle.com.
- Locate the Search box in the upper right corner of the My Oracle Support page.
- Click the sources icon to the left of the search box, and then select Article ID from the list.
- Enter the article ID number in the text box.
- Click the magnifying glass icon to the right of the search box (or press the Enter key) to execute your search. The Knowledge page displays the results of your search.
- If you see the article listed, click the link to view the abstract, text, attachments, and related products.
Parent topic: Find information on My Oracle Support
