Set up the user for MIDM access using WebLogic
To set up the user for MIDM accessing, you create the MasterIndex.Admin and Administrator groups. Then, you create a new user within the two groups. Use the user you create for MIDM access using the WebLogic Admin Console.
To set up the user for MIDM access:
- On the left panel, under Domain Structure, expand Services, and then choose Security Realms.
- In the table on the Summary of Security Realms panel, click myrealm, which is the name of the realm. The Settings for myrealm panel appears.
- Select the Users and Groups tab and then click Groups.
- In the Groups table, click New.
- In the Name field, type
MasterIndex.Adminand click OK. - In the Groups table, click New.
Administratorand click OK. - On the Settings for myrealm panel, select Users and Groups and then Users.
- In the Users table, click New.
- Type a name and a password for the new user you are creating and click OK.
- Select User Group.
- To add the two groups you created to the user you created, from the Available list, drag MasterIndex.Admin to the Chosen list, and then drag Administrator to the Chosen list.
Parent topic: Security guidelines for the middle tier
