Use Compute Instance (IaaS) Model to install OHF & OHTR in OCI
This section describes how to obtain the compute instance and install the software needed for the OHF & OHTR Middle Tier.
This approach is to obtain the compute instance of the desired shape and install the software needed for the OHF & OHTR Middle Tier. This model is that of the Infrastructure as a Service (IaaS) where in the Compute Instance from OCI is used to install the necessary software and applications in the compute instance.
This process follows the typical OHF & OHTR Middle Tier installation similar to that of on-premises installation using the OHF & OHTR OUI Installers. Please follow the installation guidelines to install OHF & OHTR in the compute instance.
- OHF Installation Guide – Chapter 5 : Middle Tier installation for OHF Middle Tier installation and
- OHTR installation guide – Chapter 3 : Install and configure Middle Tier for OHTR Middle Tier installation
Note that the prerequisite software (as JDK, Weblogic) should also be installed in the VM, as mentioned in the above installation guidelines prior to the installation of OHF Middle Tier application.
Further if it’s planned to use the Oracle Autonomous Data Warehouse (ADW) as the database, the additional following steps are also needed as part of the installation.
The installation of OHF and OHTR Middle Tier in Oracle Cloud Infrastructure (OCI) needs a staging database. This database will host the Weblogic RCU schema’s that are needed by Weblogic ADF framework. It will also serve as a staging database for OHF and OHTR schema’s during the middle tier installation process. The OHF and OHTR Middle Tier will use this staging database during the installation process. Once the OHF and OHTR Middle Tier installation using the installers are complete, a few additional steps are done to switch to Oracle Autonomous Data Warehouse (ADW) from this staging database.
Follow the sequences for the installation of OHF and OHTR applications in OCI. This section assumes that OHF and OHTR Data Models are already created in Oracle ADW.
This will cut over the database connection in Weblogic to Oracle ADW.
Parent topic: OHF and OHTR Middle Tier in OCI
