System requirements for client process systems
If you are developing an application or client process that integrates with the InForm Adapter interfaces, make sure that the following are available on the client process system:
- Connectivity to the interface.
- Certificates that are configured to work with the interface (if you are using the certificate security model).
- Firewall security that is configured to receive output from the interface.
- A port that is configured for communication.
