Date and time parsing error
Occurs
When you initiate a get job in Central Coding.
Error message
To prevent out-of-sync verbatim and query data, the ExchangeQueryUpdates job will not be run. Please resolve the following error first: Source:Central Coding. Job failed with the following error: An exception has been thrown calling the web method GetCodingData...
Possible cause
The date format of the locale specified in the trial database and the date format of the locale specified on the InForm Adapter application server are not set to the same value.
Solution
Set the locale in the database and the locale of the InForm Adapter application server to the same value.
