Choosing the deployment type
The InForm Adapter Discrepancy interface comes with:
- Three variations of the web.config file to support the different configurations that are used to deploy provisioning.
- The utility WebConfigFileSelector.cmd, which you use to set the appropriate config file for your configuration type.
To select the deployment type:
- Open a Command Prompt window and change to the <InForm_Adapter_installation_directory>\DiscrepancyService\ directory.
- Issue the following command:
WebConfigFileSelector.cmd CONFIGURATION
where CONFIGURATION specifies the deployment type.
For example:
WebConfigFileSelector.cmd F5
The utility replaces the InFormAdapter\DiscrepancyService\web.config file with one of the following files.
Deployment configuration options
Deployment type
Deployment type configuration option
Config file
Details
Default
SECURE
Web_secure.config
- Secure configuration for client requests sent over the Internet.
- Supports HTTPS transport using SOAP 1.2.
- Requires a Username Token in the SOAP Security header for providing the user name and password credentials to authenticate a request.
Load balanced
F5
Web_secure_F5.config
- Secure configuration for client requests sent over the Internet using a network load balancer.
- Supports HTTPS into the network load balancer and HTTP out of it using SOAP 1.2.
LAN access
UNSECURE
Web_nosecurity.config
- Unsecure configuration for client requests sent over a LAN from behind a firewall.
- Supports HTTP transport and SOAP 1.2.
- Does not perform request authentication.
