Deployment types - ODM Export
The InForm Adapter ODM Export interface supports network access directly to the server, network access through a load balancer, and local access. After you run the installation, you run a script at the command line, in which you state the type of deployment you want to use. For more information, see Choosing the deployment type.
Deployment types
Deployment name |
HTTP / HTTPS |
Authentication? |
URL / SOAP study matching? |
Default |
HTTPS |
Yes |
No |
Load balanced |
HTTP * |
Yes |
Yes |
LAN access |
HTTP |
No |
No |
* Represents the data sent by the load balancer to the API. |
