The application configuration file
Each web service and InForm Adapter Windows service has an application configuration file. This file contains product-specific Oracle application configuration settings.
The application configuration files are in the \bin\config directories for the interfaces. They are named as follows:
Application configuration files for services
Service type |
File name / Example |
Web service |
InFormAdapter.<interfacename>.config Example: InFormAdapter.coding.config Location: <installation_directory>\coding\bin\config |
Windows service |
<servicename>Service.config InFormServerAdapterService.config |
In the application configuration files, you can configure any of the following settings:
Configurable settings in the application configuration files
Configuration |
Use these instructions |
Error log settings. |
ChunkSize parameter for the Coding interface. |
Setting the ChunkSize parameter in the InFormAdapter.Coding.config file. |
Enable or disable ODM data reduction. |
