InForm control type
Definition
Simple Control
- Data Type is defined by the element's type.
- Length: text 255, integer 10, float 308.
Notes:
- Integer is always returned as 10 (the maximum number of digits in a 32-bit integer).
- Float is always returned as 308 (the maximum exponent for a 64-bit floating-point number).
- Significant Digit: 4.
Pulldown Control
References a codelist with the allowable values.
Text Control
- Data Type is defined by control data type (Pf_TextControl/DataType).
- Length: text Pf_TextControl/MaxLength, integer 10, float 308.
Notes:
- Significant Digit: Pf_TextControl/PFPrecision.
Radio Control
Group Control
Represented as an ItemDef per check option with the name of the option included in the form-relative RefPath in the ItemDefOID.
Datetime Control
incompleteDatetime.
Calculated Control
Text type with length = 255.
