Location of LSID components in ODM extract files
LSID component |
Location in ODM |
Notes |
Trial |
Alias used to register the study with the InForm Adapter software. |
Site ID |
AdminData/Location/@OID |
Subject GUID |
ClinicalData/SubjectData/@GUID |
Visit name |
ClinicalData/SubjectData/StudyEventData/@StudyEventOID |
Visit revision |
StudyEventDef/@Revision |
The revision of the visit in the study version for which the item has data. This value must be looked up in the metadata. |
Visit index |
ClinicalData/SubjectData/StudyEventData/@StudyEventRepeatKey |
If this attribute is not present, pass the value 1; note that you do not need ".000." |
Form name |
ClinicalData/SubjectData/StudyEventData/FormData/@FormOID |
Form revision |
FormDef/@Revision |
The revision of the form in the study version for which the item has data. This value must be looked up in the metadata. |
Form index |
ClinicalData/SubjectData/StudyEventData/FormData/@FormRepeatKey |
Section name |
ItemGroupDef/@Name |
Get the ItemGroupOID and look up the name in the metadata for that study version. |
Itemset name |
ItemGroupDef/@ItemSetRefName |
Required only if the item exists in an itemset. |
