pf:SubjectPool
Represents the source verification pool in the InForm application.
SubjectData/pf:SubjectPool
pf:SubjectPool
Attributes |
Value/Map to InForm |
PoolNumber |
The InForm Pool Number. type=xs:string. Required. One of the following values, representing the available pools that are hardcoded in the InForm software: 0—PF_SVELIGIBLE_POOL 1—PF_SVAUTO_SELECT_POOL 2—PF_SVMANUAL_FIRSTN_POOL 3—PF_SVMANUAL_UISELECT_POOL 4—PF_SVMANUAL_IMPORT_POOL 99—PF_SVEXCLUDED_POOL |
PoolRefName |
The ref name of the pool. type=xs:string. Required. One of the following values: Eligible—PoolNumber=0, indicating the pool is SV Eligible. AutoSelect—PoolNumber=1, indicating a pool whose members are automatically selected based on settings determined by the site administrator. ManualFirstN—PoolNumber=2, indicating a pool in which the first <n> number of subjects are automatically selected. ManualUISelect—PoolNumber=3, indicating that the pool members are added by being selected in the UI. ManualImport—PoolNumber=4, indicating an imported file that contains the pool members. Excluded—PoolNumber=99, indicating that the pool is excluded from source verification. |
