InformItemDef
Attributes/Children |
Value/Map to InForm |
OID |
The refname of the item. type=odm:oid. Required. |
Name |
Form-relative RefPath for the item. type=odm:text. Required. |
SVRequired |
Yes, if source verification is required for the item. type=odm:YesOrNo. Optional. |
DBUID |
Entity: Item. Property: DBUID. |
GUID |
Entity: Item. Property: GUID. |
Revision |
Entity: Item. Property: Revision. |
UUID |
Entity: Item. Property: UUID. |
SVCritical |
Indicates whether an item is marked as source verified critical in the InForm and Central Designer applications. |
