Error messages from the Discrepancy interface
Error Code/MessageID |
Operation |
Error |
TRANSACTION_PROCESSING_ERROR |
An error occurred processing a transaction {0}. |
DISCREPANCY_AGAINST_CALCULATED_ITEM |
Issue |
Cannot issue a discrepancy against a calculated item. |
INFORM_FORM_REPEATING_NO_DATA |
Issue |
Cannot issue a discrepancy against a repeating form that has no data. |
DISCREPANCY_AGAINST_ITEMSET_ROW |
Issue |
Cannot issue a discrepancy against an itemset row. Must issue against an item in the itemset. |
DISCREPANCY_TRANGEN_NOTCREATED |
Could not create an instance of the transaction generator. |
DISCREPANCY_ELEMENT_NOTCREATED |
Could not create element. |
DISCREPANCY_DBUID_NOTFOUND |
GetByCriteria, Issue |
Could not find an item associated with the requested Dbuid: {0}. |
DISCREPANCY_GUID_NOTFOUND |
GetHistory, Update |
Could not find an item associated with the requested Guid: {0}. |
INFORM_FORM_NOTFOUND_DETAIL |
Form not found: {0}. |
MAPPEDITEM_ENTRY_BLANK |
Found a mapped item entry for item {0} but it is blank. |
DISCREPANCY_INVALID_USER |
Invalid user specified. |
PATIENT_GUID_NOTFOUND |
Patient with GUID {0} not found. |
INFORM_DISCREPANCY_STATECHANGE_NOTALLOWED |
State change not allowed from {0} to {1}. |
MAPPEDITEM_PATH_CHAPTER_NOTSPECIFIED |
The chapter is not specified in the mapped item path: {0}. |
INFORM_FORM_DELETED |
The Form is deleted. InForm does not allow query management on a deleted form. |
INFORM_FORM_LOCKED |
The Form or Visit is locked. InForm does not allow query management on a locked form. |
TRANSACTIONID_INVALIDFORMAT |
The format of the requested TransactionId is invalid {0}. |
MAPPEDITEM_PATH_ITEM_NOTSPECIFIED |
The item is not specified in the mapped item path: {0}. |
MAPPEDITEM_CHAPTER_MISMATCH |
The mapped item's chapter '{0}' must match the requested item's chapter '{1}'. |
MAPPEDITEM_ITEMSET_MISMATCH |
The mapped item's itemset '{0}' must match the requested item's itemset '{1}'. |
MAPPEDITEM_PAGE_MISMATCH |
The mapped item's page '{0}' must match the requested item's page '{1}'. |
MAPPEDITEM_FORMAT_INVALID |
The mapped item's path is invalid: {0}. |
MAPPEDITEM_SECTION_MISMATCH |
The mapped item's section '{0}' must match the requested item's section '{1}' since the item resides in an itemset. |
MAPPEDITEM_PATH_PAGE_NOTSPECIFIED |
The page is not specified in the mapped item path: {0}. |
DISCREPANCY_REQUEST_CRITERIA_INPUT_LIMIT_EXCEEDED |
The request contained {0} values for {1}. The limit is {2}. |
TRANSACTIONID_INVALID |
The request must contain a valid TransactionId. |
INFORM_ITEM_HIDDEN |
The requested InForm item is hidden. |
REQUEST_LIST_EMPTY |
The requested list is empty. |
TRANSACTIONID_DUPLICATE |
The requested TransactionId {0} is a duplicate. |
MAPPEDITEM_PATH_SECTION_NOTSPECIFIED |
The section is not specified in the mapped item path: {0}. |
DISCREPANCY_BOOKMARK_INVALID |
The specified bookmark "{0}" is invalid for the current request. If a request includes a bookmark, it should be a bookmark that was returned in the response from the matching request. |
DISCREPANCY_INVALID_REVISION |
The specified discrepancy revision number {0} does not match the latest revision number {1}. |
INFORM_FORM_INDEX_INVALID |
The specified form index {0} is invalid. |
INFORM_FORM_REVISION_STALE |
The specified form revision {0} is not the most recent. |
DISCREPANCY_INVALID_SITE |
The specified site {0} is invalid for patient {1}. |
DISCREPANCY_INVALID_STATE |
The specified state is invalid: {0}. |
INFORM_VISIT_INDEX_INVALID |
The specified visit index {0} is invalid. |
INFORM_TRIALCONN_NOTFOUND_TRIAL |
Trial Connection for trial {0} was not found. |
INFORM_TRIALCONN_NOTFOUND |
Trial Connection not found. |
INFORM_USER_NOTFOUND |
Trial User not found. |
DISCREPANCY_LSID_NOTCREATED |
Unable to construct an LSID. |
INFORM_ITEM_PARSE_ERROR |
Unable to extract an InForm item from the requested XML. |
INFORM_VISIT_NOTFOUND_DETAIL |
Visit not found: {0}. |
