Elements and extensions change history
The following table contains a history changes to elements and extensions and the InForm Adapter release when they were introduced.
Extensions change history
Release
Change details
InForm compatibility notes
1.3.9
- StudyEventDef element—pf:VisitStartHours attribute added.
Compatible with all studies designed in Central Designer.
1.3.7.3
- The way in which ReviewState and ReviewStage are represented under the SubjectData element was changed.
1.3.7
- User element—pf:InFormUserType element added.
1.3.6.1
- ItemGroupDef element—The following attributes were added:
- pf:RowCount
- pf:IsFixedStatus
- pf:UsePredefinedValue
- ClinicalData element—pf:CriticalItems attribute added.
- InFormItemDef element—pf:SVCritical attribute added.
- ItemGroupDef element—pf:SVCritical attribute added.
No values for InForm releases prior to 6.0.
1.3.6
- User element—pf:Active and pf:Terminated attributes added.
1.3 SP5
- FormStatus element—pf:SVSelected attribute added.
- New elements added:
- pf:ReviewState
- pf:ReviewStage
- pf:SubjectPool
- pf:SubjectPoolChange
No values for InForm releases prior to 5.5.
