InForm Server Adapter services
The ISA allows the InForm Adapter software to communicate with the InForm software.
The ISA is required by most of the applications that use the InForm Adapter software. The ISA consists of two services:
- InForm Server Adapter Web Service.
- InForm Server Adapter Windows Service.
In the table, a check mark indicates the service or services you require, depending on the InForm Adapter interfaces and Oracle applications you want to use.
- If the application or interface you want to use requires only one of the services, install the ISA and then turn off the service you do not need.
- If some of your applications or interfaces require a particular service and others do not, you must leave the service running. For example, if you are using both the Central Coding application and the InForm Adapter ODM Export interface, you must have both the ISA Web Service and the ISA Windows Service running, with the ISA Windows Service set to automatic.
Application/interface service requirements
Application or Interface
ISA Web Service
ISA Windows Service
Central Coding
X
Clintrial Integration Solution (CIS)
X
X
InForm Adapter Discrepancy interface
X
X
X
