Using the silent install
The InForm Adapter 6.3 software includes a silent install option that you can use to install or uninstall the current version of the InForm Adapter software.
By default, the silent install program installs the following components and interfaces:
- ISA Web Service.
- ISA Windows Service.
- InForm Adapter Administration.
- InForm Adapter Central Administration.
- InForm Adapter Coding.
- InForm Adapter Discrepancy interface.
- InForm Adapter ODM.
- InForm Adapter Transaction interface.
- Register Trial Tool.
Some of the silent install options require installation parameters that you specify by editing the setup.iss file, located in the installation folder. For more information, see Silent install parameters.
