Upgrading to this release
To upgrade InForm Adapter 6.2.x to InForm Adapter 6.3, run the InForm Adapter upgrade wizard.
The InForm Adapter upgrade wizard:
- Backs up your configuration files.
For interfaces that are upgraded, the upgrade wizard creates three copies of the config files:
- InFormAdapter.<interfacename>config.NEW—The config file that is installed during the upgrade. For example InFormAdapter.coding.config.NEW.
- InFormAdapter.<interfacename>config.OLD—The original config file, for example InFormAdapter.coding.config.OLD.
- InFormAdapter.<interfacename>.config—The active config file that consists of the original content from the original file merged with the new config file.
Note: You should always review the contents of the config files after upgrading the InForm Adapter software to make sure your settings were updated correctly.
- Removes installed services and interfaces that are obsolete:
- CRF Submit interface.
- InForm Adapter Service.
- Eventing interface.
- InForm Server Adapter interface.
- Upgrades the InForm Adapter interfaces in-place, without affecting any settings in the current installation.
