Candidate element
The Candidate element is returned when a screening or enrollment action is performed in the InForm application.
XPath
ODM/ClinicalData/SubjectData/pf:Candidate
Parent element |
Child elements |
SubjectData |
DOB. ScreeningDate. |
Attributes
Attributes/children: Candidate |
Description |
DOB |
Date of birth of the candidate. type=TypeDATE. |
ScreeningDate |
type=TypeDATE. |
PatientGuid |
The GUID of the candidate. type=TypeGUID. Required. |
Revision |
The revision number of the subject type=TypeREVISION. Required. |
SiteGUIDREF |
The GUID of the site. type=TypeGUID. Required. |
Initials |
The initials of the subject type=TypeINITIALS. Required. |
State |
The state of the subject. type=TypePatientSTATE. Optional. |
ScreeningNumber |
The candidate's screening number. type=xs:String. Required. |
EnrollmentNumber |
The subject's enrollment number. type=TypeENROLLMENTNUMBER. Required. |
ScreeningFailure |
The reason for screening failure. type=xs:string. Required. |
EnrollmentFailure |
The reason for enrollment failure. type=xs:string. Required. |
EnrollmentOverride |
The reason that the enrollment failure was overridden. type=xs:string. Required. |
PatientNumberRevision |
The revision number of the patient number. type=TypeREVISION. Optional. |
