Input parameters—GetPatientForms
Takes an XmlElement that follows the GetPatientForms element schema as an input parameter. The GetPatientForms element has the following children.
GetPatientForms input parameters |
Node/Attribute name |
Description |
trial |
The study from which to retrieve the subject forms. Specify either the study name, or the study alias value that is used when registering the study through the InForm Adapter Admin interface. |
patientID |
The patient ID of the subject for which the data is retrieved. |
