ItemDef
ItemDef attributes
Attribute |
Value/Map to InForm |
OID |
Form-relative RefPath for the control. |
Name |
Item RefName. |
DataType |
See Data Type Table. |
Length |
SignificantDigits |
Revision |
GUID |
Item identifier. |
DBUID |
UUID |
Entity: Control. Property: UUID. |
ParentOID |
The parent of each ItemDef that is not a top-level ItemDef. |
ParentType |
Defines the type of parent control. If value of parent type is:
SelectionOID |
An OID that uniquely identifies the selection in a radio group. |
SelectionOwner |
For each ItemDef that is the child of a radio group selection, the OID of the CodeList that contains the codelist selection. |
ItemDefType |
Indicates the control type. Values: RadioGroup, Checkbox, Text, Calculated, PullDown, Date. |
Question |
Question text for the item that contains the control. |
SignificantDigits |
CheckboxGroupRefName |
Present when the control is contained in a checkbox group and contains the RefName of the checkbox group. |
