Input parameters—DownloadAdminDataODM
Takes an XmlElement that follows the DownloadAdminDataODM element schema as an input parameter. The DownloadAdminDataODM element has the following children.
DownloadAdminDataODM input parameters |
Node/Attribute name |
Description |
trial |
The study from which to retrieve administrative data. Specify either the study name, or the study alias value that is used when registering the study through the InForm Adapter Admin interface. |
userName |
The user ID of the user who is requesting the data. |
priorFileOID |
Optional reference to the previous file (if one exists) in a series. Type = String. |
fileType |
The type of ODM file data that is to be returned. Type = Enumeration. Enumeration values = Transactional. |
mappingVersion |
The version of the InForm-to-ODM mapping. Specify 2.0 for the most complete and accurate representation of the InForm data that is returned in ODM format. Type = Enumeration. Enumeration values = 1.0, 2.0. Default = 2.0. |
includeExtensions |
Specifies whether to include Oracle Phase Forward ODM extensions in the data that is returned from the method. Type = Boolean. Default = True. |
complianceMode |
Specifies how to handle transactions in the study that are deleted and then undeleted. Type = Enumeration. Enumeration values = Strict, Loose. Default = Strict. Strict uses a Remove transaction to indicate that a form has been deleted. If the form is subsequently undeleted, the returned data includes all the data for the form that was deleted and then undeleted. Loose uses a FormStatus or ItemGroupStatus element with the attribute name of Deleted. Loose compliance mode is more efficient. Strict or Loose has no affect on admin data or metadata. |
includeUsers includeLocations includeSignatures includeGroups includeLocales |
Parameters that specify a section in the admin data to be returned with the response. includeUsers is required if you want to specify userBookmark. Type=Boolean. Values=True or False. Default=True (the section is included). |
userBookmark |
The InForm UserID. You must specify includeUsers if you want to specify a userBookmark.
