Connecting to a study
- To start the ODM Sampler tool, double-click the OdmSampler.exe file at the following location:
<unzip_directory>\InformAdapterSamples\OdmSampler\bin
- In the Adapter Host field, provide the name of either the IP address or domain name where the resource is located. For example:
https://VanityUrl/pfst62/informadapter/ODM/ODMService.svc
- If you want to use https to connect to the server, select the Use Https checkbox.
- Select f5cert if you want to use f5cert. The certificate must be installed on your local machine and you must provide the certificate subject in the application configuration file.
<add key="IACertName" value="the subject name of the certificate to sign the soap message" />
- In the Virtual Directory field, provide the path or directory on the server. For example:
- If you are using Username authentication, select the Enabled checkbox, and fill in the Trial User and Trial Password fields. Skip this step if you are using f5cert.
- In the Trial Name field, enter the trial to connect to. For example:
pfst62
- Click Connect.
