Using a proxy server
The InForm Publisher application allows you to send messages through a proxy server. A .NET specific application configuration file allows you to specify application-wide proxy behavior using the .NET system.net.defaultProxy configuration element.
The application configuration file for the InForm Publisher application is installed with the InForm Publisher software and is located in the /Bin directory under the installation location. The application configuration file is called InFormPublisher.exe.config.
