Argus Safety only attributes
- SafetyEventUpdateInterval—Number of minutes after a safety event is pushed to the Oracle Argus Safety application that the InForm Publisher application waits to check for updates to the safety event. Specify an integer between 5 and 1400. The default is 120 minutes.
- SafetyEventAutoSendInterval—Number of minutes after a safety event is marked as serious in the InForm application that the InForm Publisher application waits before sending the data to the Oracle Argus Safety application. This setting applies only if the study is designed so that a user must choose to send a serious adverse event to the Oracle Argus Safety application by indicating that on a form. Specify an integer between 5 and 1400. The default is 120 minutes.
- SafetyErrorMaxAge—Number of hours after an error occurs that the InForm Publisher application retries the action. After the specified number of hours, the InForm Publisher application no longer attempts to retry the action. Specify a number between 1 and the value you specify for the SafetyErrorRetryExpiration field. If you do not specify a value for the SafetyErrorRetryExpiration field, there is no maximum value for this field. The default is 2 hours.
- SafetyErrorRetryExpiration—Number of hours before the InForm Publisher service is stopped and restarted; this value is used to create a time range to determine the expired errors that the InForm Publisher application attempts to reactivate and retry the actions associated with them.
For example, if the SafetyEventRetryExpiration value is set to 7, an expired error that occurred up to 7 hours before the InForm Publisher service was restarted is reactivated. The InForm Publisher then retries the action associated with the error for the amount of time specified in the SafetyErrorMaxAge setting.
- SafetyErrorMaxRetries—Number of attempts the InForm Publisher application makes to save an error to the database before logging a system error and giving up. The default is 3.
- SafetyErrorRetryInterval—Amount of time between attempts the InForm Publisher application makes to save an error to the database. The default value is 120 seconds.
