Upgrading from InForm Publisher 6.2.x or 6.3.0 to InForm Publisher 6.3.1
You can run an in-place upgrade from an InForm Publisher 6.2.x or 6.3.0 release.
On an InForm 6.2.x server, you can upgrade InForm Publisher 6.2.x to InForm Publisher 6.3.x after upgrading InForm to InForm 6.3.0 or above. You can also upgrade InForm Publisher 6.3.0 on an InForm 6.3.0 server to InForm Publisher 6.3.1 without having to upgrade InForm 6.3.0 to InForm 6.3.1.
- (Optional) Back up the InForm Publisher config file InFormPublisher.config.
The configuration file is located in <InForm Publisher Installation Directory>/Bin/Config.
- On the InForm server, run the InForm Publisher installer.
- On the installer screen, it confirms that the Installshield Wizard will update the installed version of InForm Publisher to version 6.3.1; click Next.
- After the upgrade is complete, click Finish.
- Start the InForm Publisher Windows service.
