About the InForm Publisher software
The InForm Publisher software publishes data from InForm studies that can be imported to a target application.
The data is published from a transaction queue, on a configurable schedule.
To use the InForm Publisher software with an InForm study, you must:
- Install the InForm Publisher software on the InForm application server.
- Configure the software to work with the study and the target application.
The InForm Publisher software offers two publishing options, the Argus Safety Publisher and the ODM Extract Publisher:
- The Argus Safety Publisher is used by the InForm to Argus integration. This option is only supported when InForm is hosted by Oracle.
- The ODM Extract Publisher can publish data to web service, local directory, FTP, or CTMS endpoints.
The Argus Safety Publisher is used to send data for a Serious Adverse Event to the Oracle Health Sciences Clinical One Integration Hub.
If configured for ODM Extract, the InForm Publisher application provides a way for customers to define events of interest and select the output format for publishing data from InForm studies. Transactions are based on study events (for example, data added to a subject’s study data or changes in subject status). The ODM Extract event output is in the ODM Snapshot XML format. The InForm Publisher application can publish the XML to web service, local directory, FTP, or CTMS endpoints.
ODM Extract data can serve as input for applications that require InForm data or status as needed by the requirements of the customer receiving application. This data can be sent to a variety of customer applications, including metric reporting, clinical coding, clinical repositories, and CTMS.
