ItemData
ItemData attributes
Attribute/Child |
Value/Map to InForm |
ItemOID |
Item RefName. |
Value |
ItemContext/control values. |
DBUID |
Revision |
pf:FormattedDateValue |
Indicates a value of null or unknown in the date part.
Note: To maintain backward compatibility and conform to ODM standard, "-" is still used to express a value of unknown or null in the Value attribute. If differentiation between null and unknown is required, use the pf:FormattedDateValue extension. |
