Operation—receive ODMdata
Service |
Operation |
ODMProcessorService |
receiveODMData |
ODMProcessorService details
Item |
Description |
Input |
The InForm Publisher application sends ODM extract data XML in string format to the web service. |
Output |
The web service sends one of the following return codes to the InForm Publisher application: |
SUCCESS* |
After receiving ODM extract data, the receiving application sends a SUCCESS response. |
ODMMETAREQUIRED |
The receiving application can request ODM metadata. |
ODMADMINREQUIRED |
The receiving application can request ODM administrative data. |
ODMMETAANDADMINREQUIRED |
The receiving application can request ODM metadata and administrative data. |
Fault |
If the web service is unable to process data for any reason, it returns a fault. |
Note: The web service should return a success code after receiving either ODM extract data or ODM metadata and administrative data. The remaining codes should be used only when the receiving application needs administrative data, metadata, or both.
