pf:CustomEvent element
This extension denotes the custom event for which the ODM XML is published.
XPath
ODM/ClinicalData/pf:CustomEvent
Attributes
pf:CustomEvent attributes
Attribute |
Description |
Name |
This attribute is the custom event destination name that is defined in Central Designer. This name can be meaningful to the receiving application. |
Destination |
Name of the destination that the InForm Publisher application uses to locate the endpoint to which it sends the custom event XML. |
StudyVersion |
Study version to which this custom event is assigned. |
EventID |
Internal numeric identifier of the custom event. |
EventRef |
Revision number of the custom event. |
