To add an Argus Safety Publisher subscriber
- In the Add New Argus Safety Publisher Type Subscriber dialog box, enter the information for the new subscriber:
Fields of the Add New Argus Safety Publisher Type Subscriber dialog box
Field
Description
Subscriber Name
Name for the subscriber.
Endpoint Alias
N/A
Endpoint Type
N/A
Endpoint Address
The location of the endpoint.
FTP Local Folder Path
N/A
FTP Remote Folder Path
N/A
Select trials to add to this subscriber
One or more trials to associate with the subscriber.
- Click Ok.
The InForm Publisher Configuration dialog box appears.
- After a new Argus Safety subscriber is created, you can view or edit the following configuration information.
Configuration information for Argus Safety subscribers
Field
Description
Subscriber Type
Type of subscriber, which specifies the target application associated with the subscriber.
This field is populated based on your selection in the Add New Subscriber drop-down list.
READ-ONLY
Subscriber Name
Subscriber name.
Endpoint
Web service endpoint URI that the InForm Publisher application calls to update data to the subscriber destination.
Secure Endpoint User Name
User name of the web service endpoint URI user. This field is enabled when endpoint type is HTTPS or FTP.
Secure Endpoint Password
Password for the web service endpoint URI user. This field is enabled when endpoint type is HTTPS or FTP.
Scheduled Push Interval
Interval at which the InForm Publisher software:
- Retries actions that previously failed due to errors.
- Checks to see if SAE Update Interval (mins) has elapsed and, if so, sends any necessary updates for existing safety events.
- Checks to see if SAE Auto-Send Interval (mins) has elapsed for any existing serious safety events that have not been sent yet and, if so, sends those safety events.
This value is calculated by the InForm Publisher software and is not directly configurable. The value is set to one half of the lesser value specified for the SAE Update Interval (mins) or SAE Auto-Send Interval (mins), rounded down to the nearest whole number, up to a maximum of 60 minutes. The default value is 60 minutes.
Gateway Signature Files Path
Not supported.
Endpoint Type
READ-ONLY
Endpoint Alias
N/A
N/A
N/A
Argus Safety fields
Number of minutes after a safety event is pushed to the Oracle Argus Safety application that the InForm Publisher application waits to check for updates to the safety event. Specify an integer between 5 and 1400. The default is 120 minutes.
Number of minutes after a safety event is marked as serious in the InForm application that the InForm Publisher application waits before sending the data to the Oracle Argus Safety application. This setting applies only if the study is designed so that a user must choose to send a serious adverse event to the Oracle Argus Safety application by indicating that on a form. Specify an integer between 5 and 1400. The default is 120 minutes.
Error Expiration (hours)
Number of hours after an error occurs that the InForm Publisher application retries the action. After the specified number of hours, the InForm Publisher application no longer attempts to retry the action. Specify a number between 1 and the value you specify for the Expired-Error Reactivation (hours) field. If you do not specify a value for the Expired-Error Reactivation (hours) field, there is no maximum value for this field. The default is 2 hours.
Number of hours before the InForm Publisher service is stopped and restarted; this value is used to create a time range to determine the expired errors that the InForm Publisher application attempts to reactivate and retry the actions associated with them.
For example, if the Expired-Error Reactivation (hours) value is set to 7, an error that occurred up to 7 hours before the InForm Publisher service was restarted is re-activated, and the InForm Publisher again attempts to save the error for the amount of time specified in the Error Expiration (hours) setting.
Error-DB Failure - Retry Interval (secs)
Amount of time between attempts the InForm Publisher application makes to save an error to the database. The default is 120 seconds.
Error-DB Failure - Max Retries
Number of attempts the InForm Publisher application makes to save an error to the database before logging a system error and giving up. The default is 3.
- Click Save.
